Just to follow this up - I had the mileage wrong. There was another rear tyre in there as well.
So that tyre had a total of 807.68km on it to look like that. Do Continental have a problem or is this me?
Postby Mr Purple » Tue Jan 25, 2022 2:03 pm
Postby Retrobyte » Tue Jan 25, 2022 2:31 pm
What's the road surface like on your most frequent rides? I know there's a lot of variation in road surface, even for stock bitumen roads - some are really smooth while others have a quite course texture
Postby ironhanglider » Tue Jan 25, 2022 2:49 pm
Totally your fault. Too many mad skids and burnouts!
Postby Mr Purple » Tue Jan 25, 2022 2:52 pm
Postby warthog1 » Tue Jan 25, 2022 3:08 pm
Had multiple conti GP tyres from 3000 through to 5000TL. Not used the tubed version however.
Postby trailgumby » Tue Jan 25, 2022 5:26 pm
Postby warthog1 » Tue Jan 25, 2022 6:40 pm
This might help you. Makes a strong case for hookless about 30min in.
Postby queequeg » Tue Jan 25, 2022 6:50 pm
Postby Comedian » Thu Jan 27, 2022 5:27 am
Listen to this. Do the test. It feels weird the first few days but after you've been riding it for a while you won't think of going back.
Postby Mr Purple » Thu Jan 27, 2022 10:55 am
Postby Comedian » Thu Jan 27, 2022 11:49 am
Listen to the podcast.Mr Purple wrote: ↑Thu Jan 27, 2022 10:55 amI just dropped them to 80PSI from 90PSI, and might try 70PSI next if I get through a few weeks with no pinch flats.
All the calculators give me something different - Silca recommended 90 PSI, Goodyear 70PSI. I'm with you, I think I was running them too high but not sure it contributed that much to the tyre wear.
28mm is the other option.
Postby Thoglette » Thu Jan 27, 2022 3:58 pm
Oh FFS!
Postby warthog1 » Thu Jan 27, 2022 6:28 pm
Ffwd to it.
Postby Thoglette » Thu Jan 27, 2022 6:32 pm
Indeed !
Postby g-boaf » Fri Jan 28, 2022 10:16 am
I’ve let my tyres go down to 50-60psi but that wasn’t great over the sharp bumps we sometimes have around here. Too risky for flats. So I usually keep them higher, but not up at 100 though.Comedian wrote: ↑Thu Jan 27, 2022 11:49 amListen to the podcast.Mr Purple wrote: ↑Thu Jan 27, 2022 10:55 amI just dropped them to 80PSI from 90PSI, and might try 70PSI next if I get through a few weeks with no pinch flats.
It's quicker to go stupid and work up. Like try maybe 30 and 40 at home and ride over a gutter (down first!) in your local area. You'll probably find that to low, so up another ten... and so on until you are confident. Then try it for a week. I ended up at 60 and 70 and rode it for a week. Was awesome but there was a chance of touching a rim on a sharp lip or so on. So I went to 70 and 80 and I've been riding that for years without trouble. Hardly any flats and tyres that last absurdly long compared to the old days.
It's really educational to learn how little pressure is in tyres when they feel flat". it's remarkably little. So what you are doing here is essentially cutting the crazy margins we used to have. You don't need to pump your tyres up more often (once every few days) because tyres go flat more slowly at lower pressures. But you know you've got a 5-10 psi margin. For me.. if I over inflate by 10 psi I'm like "holy crap this thing rides like a dray.. how did I ever do this?".
This is of course not to say that tubeless probably isn't a little better at this - but a lot of the benefits of tubless that people rant about can be had on normal road rims by investing a little time and getting to know your pressures.
Oh and do the other test.. find your minimum workable pressure. Then pump it up to like 120 or whatever stupid pressure we used to use. Go to the crit track and then do some laps at a comfortable power. Then let the tyres down to your new pressure and compare. Report back please. I was 1.6kph faster.
Postby Comedian » Fri Jan 28, 2022 4:01 pm
It's all about working out what is the minimum for your riding.g-boaf wrote: ↑Fri Jan 28, 2022 10:16 amI’ve let my tyres go down to 50-60psi but that wasn’t great over the sharp bumps we sometimes have around here. Too risky for flats. So I usually keep them higher, but not up at 100 though.Comedian wrote: ↑Thu Jan 27, 2022 11:49 amListen to the podcast.Mr Purple wrote: ↑Thu Jan 27, 2022 10:55 amI just dropped them to 80PSI from 90PSI, and might try 70PSI next if I get through a few weeks with no pinch flats.
Postby foo on patrol » Fri Jan 28, 2022 11:10 pm
Postby Mr Purple » Sat Feb 12, 2022 10:03 pm
Postby Mr Purple » Sun Feb 13, 2022 1:10 pm
Postby stevenaaus » Sun Feb 13, 2022 1:38 pm
Mate - i know you put out some power on mean gradients, but i think there's something else affecting your tyre wear.
Postby Mr Purple » Sun Feb 13, 2022 2:26 pm
Postby P!N20 » Sun Feb 13, 2022 2:40 pm
Postby Mr Purple » Sun Feb 13, 2022 2:56 pm
Postby warthog1 » Sun Feb 13, 2022 3:12 pm
Postby stevenaaus » Mon Feb 14, 2022 7:37 pm
Users browsing this forum: blizzard
