Surly vs Soma vs Salsa
- RonK
Re: Surly vs Soma vs Salsa
Postby RonK » Mon Nov 28, 2016 7:20 am
But personally for a touring bike I leave it as high as possible - for long-distance comfort I want the bars at least as high as the saddle.
- baabaa
Postby baabaa » Mon Nov 28, 2016 8:03 am
With a Hope head doctor and steel tube you are really flexible in finding the best height, so just find more spacers add them below and then keep moving the stem down and the spacers up until you find the right length for your type of riding. Once you cut through that steerer, that’s it. These forks are pretty solid so I wouldn’t stress about the length at the moment. The end result is you may have a bit of cable housing slack (maybe, full length housing anyway?)
Postby uad782 » Mon Nov 28, 2016 12:36 pm
I guess I have to do at least one cut straight up though. The reason being (as can be seen in my picture) is that even with 120mm of spacers I still cannot pre load the bearings. So I suppose it may require two cuts - I will start with the 85mm of so as recommended by Baabaa and trim from there.
- baabaa
Postby baabaa » Mon Nov 28, 2016 1:12 pm
Postby uad782 » Mon Nov 28, 2016 8:49 pm
http://www.this link is broken.au/park-tools-hom ... -cup-press
Postby Uncle Just » Mon Nov 28, 2016 9:49 pm
In times past I've also used a wooden dolly and a softish piece of wood over the cups to put them in but sometimes they go askew.
- RonK
Postby RonK » Mon Nov 28, 2016 11:39 pm
Seems likely the washers you have are not heavy enough. When I say plate washers I'm thinking big ones like this.
![Image](http://www.allfasteners.com.au/media/catalog/product/cache/1/small_image/210x/9df78eab33525d08d6e5fb8d27136e95/6/h/6h.019.jpg)
Also - are you try to pull both top and bottom in at the same time. If so, try just pulling in one at a time.
Postby uad782 » Tue Nov 29, 2016 7:16 am
I will try and get some real plate washers. I did not realise how much force was required to set the headset cups. I double checked the sizes of the cups and headtube with some calipers and measured that the headtube is about 0.1mm thinner.
I note the Hope website says the chamfer the inside.
What also surprised me is inside diameter of the headtube is a constant diameter from top to bottom. The outside has the top and bottom widening out and I thought it must widen out to allow the fitting of the cups. I guess the thicker steel is for both aesthetics and maybe strength. Looking at the Hope pictures it shows all headtubes as being wider where the cups are inserted.
- baabaa
Postby baabaa » Tue Nov 29, 2016 9:00 am
- RonK
Postby RonK » Tue Nov 29, 2016 9:45 am
Hehe - that is why I was saying you can't pull them in by the preload.uad782 wrote:I did not realise how much force was required to set the headset cups.
The Cane Creek headset pulled into the Fargo head tube fairly easily but some I've fitted took a fair bit to get them started.
Postby uad782 » Tue Nov 29, 2016 8:55 pm
I got it
![Smile :)](./images/smilies/icon_smile.gif)
I went to Bunnings and got some bigger threaded rod and 50mmx2mm square washers. Once again on the first go had no luck.
So I got a file (for my chainsaw) and filed inside on both ends of the headtube. This helped to seat the cups and they went in relatively easily. I had two washers on either end and they were still bowing (elastic deformation-shows how much force was applied) when inserting. The other trick was when the cups look like they were going to misalign I moved the rod and washer to add force over the area that needed it.
That was my last go before I was going to follow in Baabaa's footsteps and head to the LBS.
So thanks to everyone for your help, it is much appreciated!
- RonK
Postby RonK » Tue Nov 29, 2016 9:38 pm
Postby uad782 » Fri Dec 02, 2016 6:37 pm
However, I successfully inserted the head doctor but I overtightened it breaking the bolt. The bolt appears to be a very weak alloy. My plan was to over-tighten so the fork would not rotate and back off from there.
This used to work with ball bearing headsets but I realise over-compression onto the cartridge type probably doesn't work.
It looks like I am up for a new head doctor as I doubt I can get the bolt easily.
- baabaa
Postby baabaa » Fri Dec 02, 2016 7:39 pm
Postby uad782 » Fri Dec 02, 2016 9:35 pm
After the snap I read on a few forums how weak the bolt is. I was pretty chuffed I got the expander section to work because that also gets a bagging.
I think I will cut my losses and get a cheaper, standard star nut and cap. I may still email Hope and see what they say.
Postby uad782 » Tue Dec 06, 2016 7:02 pm
I have mounted the caliper on the back with it seeming to fit well. However, when I mount the wheel, the inside brake pad rubs on the disc. I have tried adjusting the caliper positioning with no luck. A while ago you mentioned some Syntace shims. I assume I could use these to move the disc out from the centre.
By using the shims am I masking an underlying problem as I thought it should all fit nicely.
http://www.eightyonespices.com.au/#!pro ... et-of-8%29
- RonK
Postby RonK » Tue Dec 06, 2016 7:42 pm
I don't recall what caliper you have. With the Spyres it was just a matter of fitting the caliper loosely and connecting the cable, squeezing the brakes to centre the caliper and tightening the caliper bolts while holding the brake on.
Remind us what caliper you have.
- baabaa
Postby baabaa » Tue Dec 06, 2016 7:59 pm
BB7s I just do the loosen caliper bolts, take tension off cables via in-line adjusters (and if not enough room at first at the quick release on the brake levers and then again down at the caliper), open pads so plenty of play with the rotor, drop in wheel and close in the inboard pads to grab rotor first, then snug down with outboard, tighten caliper, back off pads several clicks and re-adjust cable tension.
If you have BB7 mtn, get some in-line adjusters, they really help with drop bar levers. Once again the salsa steel frames seem pretty well set, so shims should be way down the list.
Postby uad782 » Tue Dec 06, 2016 9:31 pm
- RonK
Postby RonK » Tue Dec 06, 2016 9:41 pm
Have you adjusted the pad clearance? There is an allen key socket on both sides - 3mm I think. You should be able to adjust a pad in and the other pad out.
Postby uad782 » Wed Dec 07, 2016 6:46 am
I haven't tried that adjustment yet. I hope there is a bit of movement available. I think there won't be enough. I might also try mounting an old shimano caliper to see how it looks in comparison.
I also note TRP don't have much supporting documentation for the Spyke compared to the Spyre. I suppose they are similar.
- RonK
Postby RonK » Wed Dec 07, 2016 7:14 am
Postby uad782 » Wed Dec 07, 2016 9:45 am
I will investigate any difference between the spyre and spyke
- RonK
Postby RonK » Wed Dec 07, 2016 10:14 am
When I fitted Spyres to my Salsa Fargo they literally fell on, and I recall Andrew (Aushiker) commented that fitting Spykes to his Salsa Mukluk was easy.
Here's a how-to-do the pad adjustment
Postby uad782 » Wed Dec 07, 2016 9:03 pm
First I note the Spyre and Spyke are pretty much the same brake. The difference is the Spyke has a cover on it for mud etc.
I spent a fair bit of time tonight mixing and matching with no luck. I tried an old set of Shimano and Magura louise calipers with them both rubbing on the inside pad. I tried swapping both sets of Spykes and adaptors with no luck. I also put another wheel in the frame with the same result.
Therefore I conclude it is either the TRP adaptor or the Salsa frame. I figure I could easily solve the problem by installing a half mm washer between the frame and the adaptor. However I am still concerned I have the problem.
Any comments once again appreciated.
- All times are UTC+11:00
