stevenaaus
Postby stevenaaus » Sat Dec 14, 2024 3:53 pm
Two :)? Duck, how many different shimano crankset caps? I think there's more than two.
warthog1
Postby warthog1 » Sat Dec 14, 2024 6:04 pm
Well as much as I have raved about my Ultegra di2 FD shifting, I have dropped the chain a few times and did it again today. Going small to big it dropped all together onto the bb area. I had it in the 4th cog from the top (inside) of the cassette. Kept pedaling but it got sucked into the bb area by the chainring and scratched the frame :x Will need to get some touch up paint.
Decided that aint happening again so I stole the chain catcher off my S5, which has the same damage. Anyway thought I better work out how to setup a di FD so watched this;
Wasn't too hard. Easier than a cable derailleur without having to stuff around with cable tension.
Seems to shift well and the screw that supports the derailleur laterally under load butts onto the derailleur hander on the Reacto. Happy with that. :)
Also noticed whilst stuffing around that a 32mm tyre on the 25mm int WR50 is about as wide as I can go. It is reasonably close to the FD. Measures 35mm, so wide enough for a roadie anyway.
Postby Duck! » Sat Dec 14, 2024 6:37 pm
Two thread diameters, four different bolts. Most of the earlier generations and later low-spec models of Hollowtech II cranks have a thick-walled aluminium spindle, therefore use the smaller diameter bolt. Others have a thin-walled steel spindle which uses the larger diameter. 7800 Dura-Ace used an aluminium bolt that is otherwise the same as the larger bolts. MTB models also use the larger diameter, but are longer, therefore will bottom out the threads if used in road cranks and not pre-load.
Postby jasonc » Sat Dec 14, 2024 9:50 pm
Got a mate running r7020. He's just bought an r7170 groupset. Can I use the same hydro cables?
Postby Duck! » Sat Dec 14, 2024 10:33 pm
^^ Yes, the hydro parts are unchanged.
Postby jasonc » Sun Dec 15, 2024 8:05 am
Winning. Thanks duck
warthog1
Postby warthog1 » Tue Dec 17, 2024 9:45 am
That chain catcher has been a big plus. Not hard to fit either with the di2 FD, easier than a cable operated derailleur. The derailleur is working great too. I think the shifts are better if anything. Might have been out a bit previously. Using the support screw to adjust it in line, as per that video, worked first pop. :) Wish I did it first up when I got the bike.
Postby jasonc » Tue Dec 17, 2024 10:28 am
BTW - this worked. so running r7020 brakes with r7170 shifters
MichaelB
Postby MichaelB » Wed Dec 18, 2024 10:14 am
So finally after moving g house, and the TdU ride coming up, decided to finally get off the proverbial and rebuild the Hint rear wheel that I killed on a pothole a while ago.
I bought the rims, and of course the ERD did t quite match for the original spokes, so went and bought some slightly shorter, and the house move took precedence.
But now can’t find the rear hub ….. :shock:
PFBB.
Anyone got some 24 hole rear hubs up for grabs …..
davehirst
Postby davehirst » Thu Dec 19, 2024 1:16 pm
Although it requires building the wheelset twice, I have found the best thing to do is go out and buy another hub and build the wheel.
The next day you will be looking for something else and you will find your hub.
Pull apart the first wheel, return the hub then you can build your wheel.
Works for me.
Postby jasonc » Thu Dec 19, 2024 1:22 pm
Works for me.
Murphy's law
davehirst
Postby davehirst » Thu Dec 19, 2024 1:52 pm
No, its the Opposite of ochams razor.
:-P
MichaelB
Postby MichaelB » Fri Dec 20, 2024 9:10 am
Works for me.
That's what will happen in the ned, but need the hubs 1st and 24H & straight pull are not cheap !!!
Some googling coming up, but likely to be a Novatech ....
MichaelB
Postby MichaelB » Fri Dec 20, 2024 9:40 am
PFBB.
As expected, 24H rear hubs, let alone straight pull are few & far between or are ridiculously expensive.
Cheapish & unknown with no dwgs to calculate spoke lengths ZTTO from Aliexpress (AT)$100
Novatec options - D412CB Straighpull or D792SB Flanged both available w dwgs, but exchange rate is crappy atm .....
EDIT :
Bitex BX312R are also an option, but not cheap (US$123), and Novatec seem to be4 not available to ship to Aus ....
twizzle
Postby twizzle » Sat Dec 28, 2024 4:20 pm
Setting up the old alloy Ribble Winter frame for crit racing, using my TT crankset. 42/55 rings, 11/28 cassette. Instead of big/small/vertical jockeys, I did the chain using the big/big + two links as that's the new standard for 28+ cassettes. But I could not get it to shift both in/out of the 11T when in the 55. Played with jockey wheels, cable grease, on and on... much swearing.
I finally went back to the B screw. Even with the B screw removed and in the lowest gearing, the upper jockey was no-where near the 28T. Add an extra two links to the chain, re-tune the gears and now it works like magic.
I'm thinking back over the years, how often I've struggled with consistent shifting. :|
I ride, therefore I am. But don't ride into harm's way.
MichaelB
Postby MichaelB » Sun Jan 05, 2025 6:07 pm
PFBB.
And found it ….
Phew
warthog1
Postby warthog1 » Sun Jan 05, 2025 6:27 pm
Nice Michael :)
elantra
Postby elantra » Sun Jan 05, 2025 10:29 pm
PFBB.
And found it ….
Phew
You usually find these sorts of important thingos when you are looking for something else completely unrelated :lol:
Postby Duck! » Sun Jan 05, 2025 10:43 pm
PFBB.
And found it ….
Phew
So true!
Andy01
Postby Andy01 » Mon Jan 06, 2025 9:40 am
PFBB.
And found it ….
Phew
And usually about a week after you went out and bought a new one (because you couldn't find it) :lol:
Postby jasonc » Mon Jan 06, 2025 11:54 am
Tried setting up my new (tubeless) gravel wheels yesterday. installed 22mm wide rim tape in 24.5mm internal width wheels. inflated. heard lots of pops. looked good. came back an hour or so later. both flat. on one of them i could hear the air coming out between the tyre and the rim. so i threw in sealant figuring that might seal it. nope. leak must be elsewhere. i think i need wider rim tape.
warthog1
Postby warthog1 » Mon Jan 06, 2025 12:32 pm
Tubeless tape needs to go right to the vertical inner edge of the rim afaik.
Given it needs to be pushed down into the curved hollow in the middle of the rim it needs to be wider by the sounds of it.
When I seat a tubeless I then put the sealant in (45mm gravel ~70ml) reinflate and put the wheel on its' side and slowly wobble/rotate it around so the sealant meets the bead seat. Do that for both sides.
I am self taught but I have about 50k km on tubeless now and it has worked.
biker jk
Postby biker jk » Mon Jan 06, 2025 1:18 pm
Yes the rim tape needs to be 2-3mm wider than the internal rim width. Try 27mm wide rim rape.
Postby jasonc » Mon Jan 06, 2025 1:22 pm
MichaelB
Postby MichaelB » Mon Jan 06, 2025 2:08 pm
Nice Michael :)
Now just gotta build it ......
Actually, I found it pretty easy, so all good in the end.
