Climbing, out of the saddle.... less energy efficient?
- cyclotaur
Postby cyclotaur » Thu Nov 05, 2015 9:19 am
My fastest times (and my my most common comfortable times) have all been achieved in the saddle with no need to stand. I'm currently not so fit and need regular standing efforts to maintain/regain speed and rhythm simply to achieve times. quite a bit slower than my usual 24-25mins, much less the 21-22mins of my fastest times.
So when I'm fit I achieve overall better times on steady climbs by staying seated. I know from experience trying to beat my best time that I 'blow up' if I try to push with standing efforts when I'm already close to my limit being seated.
Irrespective of my relatively slow 1:20 times I suspect other riders would have a similar experience on similar or longer climbs.
Shorter climbs are a different issue as I can sometimes complete the climb before emptying my 'tank' completely through standing efforts. Eg. I go a lot better on the shorter Ridge Rd climb to Skyhigh, on which I can use standing efforts quite effectively.
My old blog - A bit of fun
- kb
Re: Climbing, out of the saddle.... less energy efficient?
Postby kb » Thu Nov 05, 2015 9:36 am
- g-boaf
Postby g-boaf » Thu Nov 05, 2015 9:42 am
If he is right or not, not for me to judge. I'm not that fast. But I find on longer hills I stay seated, except for short little bits where I stand.
Postby vosadrian » Thu Nov 05, 2015 9:46 am
On the HR thing.... I find that standing my HR can be lower (If I resis the urge to go faster). Actually generally at lower cadence at the same speed my HR can be lower, but my legs will hurt more. Faster cadence seated seems to move the load into the cardio system and I can maintain high HR longer than sore legs.
- g-boaf
Postby g-boaf » Thu Nov 05, 2015 9:56 am
If my HR goes high, I grab a higher gear until it settles down. And hope the legs don't burn up. I tend to prefer staying at higher cadence, I can handle the higher heart rate for longer too, but if my legs are starting to really hurt then I'm in trouble. As long as I stay on top of the gear, I'm fine.
Postby cj7hawk » Thu Nov 05, 2015 10:41 am
I think it depends on whether your knee is locked mostly - If your knee is straight, then the conduction of force is mostly through the bone. If your knee is bent, then the muscles burn energy maintaining tension.vosadrian wrote:Interesting stuff David,
I wonder if the force applied at BDC and TDC costs us much energy. I mean I stand on the ground without moving and apply force to the ground without moving and therefore do no work, and equally it does not cost me much energy as opposed to walking/running when I am moving (and doing work as opposed to just applying a force). I am just questioning whether supporting the weight of our bodies on the pedals as opposed tot he saddle during the TDC/BDC phase is really costing us as a loss of energy doing work? No matter what, we are always applying the force of gravity from our mass to the bike in some way.
I find that when I am climbing up a steep climb and need to stand and at the same time limit the work I am doing so I can make it to the top without stopping, I will get in the lowest gear I have and then reduce my cadence. The end result is that the bike accelerates quickly as I put my weight on the pedals after TDC to BDC, but I come to almost a stop at BDC before the other side comes over TDC and then accelerate again. The bike is accelerating and decelerating quite a bit, and I am really using my weight on the pedals between TDC and BDC to propel the bike and coasting through TDC/BDC. I am not using much energy in the coast phase but quite a bit in the power phase.
So if you're going up and down like a yoyo, and standing straight up on the pedal, then you're probably not using much energy at TDC.
I don't know how that otherwise effects muscle efficiency though -
David
- silentC
Postby silentC » Thu Nov 05, 2015 10:51 am
- Me
- Kalgrm
Postby Kalgrm » Thu Nov 05, 2015 10:56 am
(I'm not great at it and certainly no longer fit enough to do it for long, but circular pedalling whilst standing is the only way to maintain traction and enough power on a short, steep mountain bike climb on a loose surface.)
Graeme
Postby vosadrian » Thu Nov 05, 2015 1:00 pm
That is my experience. I find I perform best at 95-100 cadence and can have my HR sit very high (average 180) for a fair while (20 minutes) if pushing it. If I lower the cadence, the HR goes down, but legs burn up and I go slower. If I go above about 105 cadence for a longer period I start bouncing off the free hub ratchet as I cannot keep a constant torque against the pedals.g-boaf wrote:Lower cadence and lower heart rate is normal though, isn't it?
Postby cj7hawk » Thu Nov 05, 2015 2:36 pm
If you look at few circular-pedaling crank-angle vs force charts, there's still significant issues while standing. It would contribute a much higher overall force though - but still doesn't address energy loss at TDC and BDC.Kalgrm wrote:This is assuming the efficient "circular pedalling" is not being used. Even when standing out of the saddle, an efficient rider will be using as much of the pedal cycle as possible to avoid surges in power during the stroke.
Graeme
Regards
David
Postby Calvin27 » Thu Nov 05, 2015 2:56 pm
I find the off saddle more energy efficient which is why most people burst off the saddle to scale small climbs. But the reality is we can't sustain this so efficiency is out the window.
We really have to look at efficiency from a whole of systems perspective. It's kind of like saying the peak efficiency of a car is at 7000rpm. That's good and all, but if the radiator cannot keep up with heat rejection, it's pointless.
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
- silentC
Postby silentC » Thu Nov 05, 2015 3:25 pm
You can get to the top of a hill pretty quickly off the saddle, and for shortish climbs I will always prefer that to sitting down and spinning a lower gear. Another guy I ride with has an average cadence >90 and he does not lift his bum off the seat ever. He can beat me up a hill if we are both sitting but I can leave him behind if I stand up. However if I try to do that over a 2 or 3km climb I will blow up and he will catch me anyway. My preferred tactic for catching that particular guy is to sit on his tail up the hill and then sprint past him to the top. Only way I can do it.
If you sit back and pace yourself on a low gear, you can go all day. That is sustainable and I guess by extension you would consider that to be efficient, because you are minimising your energy expenditure and therefore increasing the length of time you can do it. But I have to be in a patient mood or distracted by conversation to do that.
If you are only going up one hill, it doesn't really matter how much energy you use and out of the saddle is, for me, the fastest way to get there. Personally I hate hills and can't wait to get to the top of them. But if there are many hills or long climbs, sitting is the only sustainable method for me.
- Me
Postby zill » Thu Nov 05, 2015 8:12 pm
Might be due to the trainer. I use the kinetic rock and roll which is designed for riding out of the saddle.g-boaf wrote:How so? I take it by that you are doing 20 minutes out of the saddle the entire time you are riding on a trainer?zill wrote:It's clear that riding out of the saddle in the trainer on a big gear is easier than riding out of the saddle on the road whether climbing or not. Given that it is easier to generate more power when out of the saddle, this means one is able to get a higher 20 minute power riding out of the saddle on a trainer.
You must be about the only one.
Yes, do entire 20 min out of the saddle. Wouldn't like to imagine my 20min power in the saddle on that trainer. Would do much better on a cassette mounted trainer in the saddle.
Postby zill » Thu Nov 05, 2015 8:27 pm
No one likes hills but it's usually only on the hills that you can drop people and that feeling of dropping others more than compensates the hard effort output.silentC wrote:Personally I hate hills and can't wait to get to the top of them. But if there are many hills or long climbs, sitting is the only sustainable method for me.
- silentC
Postby silentC » Thu Nov 05, 2015 8:40 pm
- Me
Postby Dave-in-LK » Fri Nov 06, 2015 1:41 am
Then develope a nice steady cadence. I was always a stander but since turning 40 I found this method better and more energy efficient - for me. It also allows me to breath better taking in more oxygen ...look I don't know if that's true but it feels like
It's weird but for me it's working and I'm climbing much better
- silentC
Postby silentC » Fri Nov 06, 2015 9:06 am
It is. What you describe is exactly how a lot of people who know what they are talking about recommend you climb.look I don't know if that's true but it feels like
- Me
Postby Dave-in-LK » Fri Nov 06, 2015 9:38 am
That said what works well for one won't work well for another.
I found by standing that a lost enegwry with body movement ...shoulders and arms. Whereas staying seat but upright
Now I Might be slightly quicker in some hills standing up but the energy list meant I lost that gain on the flat or the descent or at the end of the ride ...say last ten Km
Postby cj7hawk » Fri Nov 06, 2015 10:23 am
For example, a person pushing a trolley gently does a lot more work than someone trying to push over a building. In fact, anyone doing about anything does a lot more work than someone trying to push over a building.
Except the person attempting to push a building over ( and not getting anywhere ) isn't aware that they aren't being very efficient, because all they know is that they are putting in a lot of effort. As a result, such an activity as zero percent efficiency.
Efficiency isn't something you can tell by feedback to your senses. It's something that has to be measured and understood, and it's based on distances actually moved over time. As I mentioned earlier - a crank is only 63% efficient in one direction if the force on the crank is constant. When you climb out of the saddle, this inefficiency is in play 100% of the time. It doesn't matter if you pedal using some special technique - at best, you will only convert the force from your mass into torque at 63% efficiency. You can add other sources of force, sure, but you can never get rid of that inefficiency in the primary source of force.
If you sit down, you eliminate that source of inefficiency - though you may well introduce others. Still, it's a big inefficiency, so it's probably the single biggest contributor to the difference between seating and standing.
I can draw up some diagrams to illustrate this if it helps anyone?
Regards
David
Postby vosadrian » Fri Nov 06, 2015 10:44 am
I do agree with your assessment of efficiency being measured as opposed to felt... but really... does efficiency matter? What matters is the level of effort required by the rider, and whether it is maintainable for the duration of the climb and whether it leaves you more/less fatigued after the climb. If this is related to actual energy efficiency I don't know. Perhaps a rider is better served to be less energy efficient, but to use muscles that are better prepared for more work instead of being more energy efficient and using muscles that fatigue quickly? This may elevate the HR more, but if the cardio system is up to that, it may be a better outcome for the rider.
- cyclotaur
Postby cyclotaur » Fri Nov 06, 2015 10:46 am
Only pros, whippets and/or generally classy riders can manage standing climbing on higher gears for any length of time.
For most of us, I say thank goodness for modern lightweight bikes and gears that enable us to tackle big climbs largely from the saddle. These allow us to complete big climbs without exhausting ourselves or cooking our legs for the rest of a longish ride.
Riding is so much fun that I'm glad I can do big rides with big climbs every now and then. Riding 'efficiently' is the crucial thing that allows me to complete (not COMPETE) such rides.
I rode with an underprepared mate last year up Buffalo in the AAC140. I was comfortably seated in low gear the whole time, whereas he was forced out of the saddle quite regularly to maintain cadence. Good fitness allows you to ride more efficiently which allows you to ride further/higher etc ...but it's a chicken and egg thing.
Postby Dave-in-LK » Tue Nov 10, 2015 9:02 pm
I have been swimming a lot to build up lung capacity when I can't ride
Half an hour high intensity swimming taking few breaths really helped my cycling
I'm a bigger rider at 86-87 kg but fitness is ok. Goal weight 80kg. I was 105kg 18 months ago.
What I noticed was tempo and finding it on hill and not spending all my tickets too early on the climb and blowing up half way up the hill - you have to know what you're can and can't do, ride smart and as you get fitter you can climb better. I found standing wasted so much energy for me, I now only stand to give the back or legs a stretch for a few strokes then sit again in the upright position.
It comes down to power to weight ration also.
- All times are UTC+11:00
