When will M2 reopen...
warren.suen
Re: When will M2 reopen...
Postby warren.suen » Mon Mar 09, 2015 2:08 pm
i pretty much take gorehill to work each commute, but i wasn't sure if it was that bad going up the highway.. its much less stress to be on the bike path just rolling down.
i turn off at willoughby rd and get onto some backstreets to work in st leonards
SheikYerbouti
Postby SheikYerbouti » Wed Apr 22, 2015 11:28 am
Large area of de-surfacing on the M2 westbound just before the Windsor Rd exit, bike lane and lane 1 lost bitumen and is down to the road base. Likely to be unsuitable for riding for a bit.
Boognoss
Postby Boognoss » Wed Apr 22, 2015 12:30 pm
Nasty but I saw on the traffic app that it was being attended too. Perhaps only to make passable for motor vehicles until the rain stops though. I can imagine that they could lay bitumen and have it set in this weather.
Hergest
Postby Hergest » Wed Apr 22, 2015 12:45 pm
I drove past it about an hour ago, it didn't look too bad in that it appears to be a concrete section underneath and the bitumen layer has peeled off. If that's the case then an overnight work crew could lay some new bitumen without too much strife once the rain stops.
13 LynskeyR230 01 Lemond BuenosAires
queequeg
Postby queequeg » Wed Apr 22, 2015 1:55 pm
Hergest wrote:I drove past it about an hour ago, it didn't look too bad in that it appears to be a concrete section underneath and the bitumen layer has peeled off. If that's the case then an overnight work crew could lay some new bitumen without too much strife once the rain stops.
Peeled off to where?
Xplora
Postby Xplora » Wed Apr 22, 2015 2:28 pm
AHHHH yeah this caused a huge traffic snarl this morning.
Hergest
Postby Hergest » Wed Apr 22, 2015 2:34 pm
Whence it came.
Scott2468
Postby Scott2468 » Wed Apr 22, 2015 3:34 pm
They are unloading the bitumen layer now (3:00pm). No sign of workers, bitumen trucks or rollers as yet but I assume it will be laid tonight and all will be good tomorrow morning.
ed933
Postby ed933 » Thu Apr 23, 2015 9:17 am
The weather has calmed down, but there is lots of debris, especially wet leaves and branches, on the eastbound shoulder from Pennant Hills Road. Careful out there!
Boognoss
Postby Boognoss » Thu Apr 23, 2015 9:28 am
ed933 wrote:The weather has calmed down, but there is lots of debris, especially wet leaves and branches, on the eastbound shoulder from Pennant Hills Road. Careful out there!
IMO the shoulder at that point is way cleaner than usual and than I expected. Most of the debris must have been blown or washed away.
queequeg
Postby queequeg » Thu Apr 23, 2015 12:41 pm
The yellow hard hat has been there for weeks now. They clearly don't do much sweeping.
caneye
Postby caneye » Thu Apr 23, 2015 4:34 pm
at least the big fat rat is gone!!
ed933
Postby ed933 » Fri Apr 24, 2015 12:02 am
I agree, the situation wasn't particularly bad immediately after Pennant Hills road. What I meant to say is that the shoulder was rather nasty at around the Brown's Waterhole exit. This was at about 8:20 this morning.
Talking about Brown's Waterhole, a workmate told tried to cycle in through there from South Turramurra on Tuesday. 'Tried' being the key word there.. The creek was flooded about 1.5m above the path's surface!
queequeg
Postby queequeg » Fri Apr 24, 2015 5:54 am
That fits with the survey I did on Wednesday afternoon on the way home. You could see the debris in the trees at that height.
http://youtu.be/hUtb2TlNUxA" onclick="window.open(this.href);return false;
am50em
Postby am50em » Fri Apr 24, 2015 9:01 am
It appears the small part of the M2 where I ride has been swept in last 24 hrs. I noticed that the broken wood chunks and other debris just past the Norfolk tunnel has gone (finally after more than a month).
trek52
Postby trek52 » Fri Apr 24, 2015 11:41 am
Yeah i rode the full length today and it has been swept the whole length east bound. Well done M2
queequeg
Postby queequeg » Fri Apr 24, 2015 12:59 pm
am50em wrote:It appears the small part of the M2 where I ride has been swept in last 24 hrs. I noticed that the broken wood chunks and other debris just past the Norfolk tunnel has gone (finally after more than a month).
My yellow hard hat checkpoint is gone.....nooooooo!
caneye
Postby caneye » Tue Apr 28, 2015 1:07 pm
There was an incident Westbound immediately after the Beecroft tunnel exit last night, around 6pm.
Saw the cops speaking to the driver and cyclist.
Cyclist was on his feet so I'm hoping he's ok. A car was parked on the hatched lines between the exit and M2.
I can only suspect that there might've been some sort of contact when the car belatedly exited M2 whilst the cyclist was crossing to continue on westbound.
Stay safe guys.
hugh stone
Postby hugh stone » Wed Apr 29, 2015 8:11 am
Not good. Hate those off ramps - particularly hairy at night.
Also beware of a short patch of grooved road near pennant hills.
queequeg
Postby queequeg » Wed May 06, 2015 11:55 pm
From Bike North:
We have been advised we are losing access to the M2 between Pennant Hills Road and Windsor Road for 4 years starting in August.
Not sure if this is both Westbound & Eastbound, or just Eastbound.
wellington_street
Postby wellington_street » Thu May 07, 2015 12:02 am
Well that didn't last long
rogan
Postby rogan » Thu May 07, 2015 11:49 am
Almost certainly both directions. The design calls for major roadworks on both sides of the M2.
http://northconnex.com.au/southern_interchange.php
queequeg
Postby queequeg » Thu May 07, 2015 11:53 am
rogan wrote:Almost certainly both directions. The design calls for major roadworks on both sides of the M2.
It was unclear as the works mostly involve the control centre and portal on the Northwest corner of the intersection. Not sure how it is going to affect my access to/from the M2 as I use PHR between the M2 and Castle Hill Rd, and that is going to have a lot of construction.
SheikYerbouti
Postby SheikYerbouti » Fri May 08, 2015 2:54 pm
queequeg wrote:From Bike North:
You are f****ing kidding. What a joke. The bike lane has only been open for what, 6 months? My standard Sunday arvo training ride is Nth Syd to Castle Hill and I'm just about to start a commute from Naremburn to Plumpton down the M2 and M7. It's bloody hard to find another way to do those km wholly in a bike lane.
queequeg
Postby queequeg » Fri May 08, 2015 11:54 pm
Here we go:-
http://northconnex.com.au/m2_integration.php" onclick="window.open(this.href);return false;
Basically, adding a 3rd lane from PHR to Windsor Rd Westbound (should have done that during the upgrade already!), starting late this year. So, there goes cyclist access West of PHR for Westbound users. My understanding is that Transurban has given additional information to Bike North, and the end result is you should enjoy the M2 between PHR and Windsor Rd while it lasts, because you'll be back to the "yet to be determined detour", which I am almost 100% certain will be the same crappy detour they had for the M2 Upgrade itself.
Even those of us exiting at PHR and heading North will have to deal with the fact that the entire Western side of PHR up to Eaton Rd will be one huge construction zone, and I suspect the existing shared path on that side will vanish. It is unclear if they will widen the Eastern side along the Golf Course.
