The marketing claims that some people fall for are just amazing.RobertL wrote:Well, it's a target-rich environment!Tim wrote:...the gullible cycling community...
Christopher had a look at Eurobike and the display model is already broken
![Laughing :lol:](./images/smilies/icon_lol.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Postby MichaelB » Fri Sep 06, 2019 9:45 am
Postby Duck! » Sat Sep 07, 2019 6:50 pm
Don't think that's quite the proof of concept they intended!MichaelB wrote:
Christopher had a look at Eurobike and the display model is already broken![]()
Postby g-boaf » Sun Sep 08, 2019 9:43 am
I don't have a ceramic speed bottom bracket, but my bike does have a slightly cheaper Kogel one - it does spin a lot more freely and seems to be more so now that it is run in quite well. I ended up going for the version aimed at cyclocross - it's been pretty much flawless running over a lot of kms on my road bike.Tim wrote:Seems to me Ceramicspeed are in the business of selling outrageously expensive, unnecessary products to the gullible cycling community.
For example, ceramic bottom bracket bearings. Great bearings for high speed, high temp applications eg. bearings spinning at 10,000 RPM+. How fast do I peddle? About 85 RPM.
Postby Duck! » Sun Sep 08, 2019 2:21 pm
Most of the drag in a regular bottom bracket is the seals rather than the bearings. Shimano models in particular have a dirt seal under the outer cover that does drag a fair bit, but it's very effective at keeping crud out of the bearings. Gently lifting off the outer covers & applying a bit of Slick Honey grease or silicon lube to the lip of the inner seal cuts drag enormously.g-boaf wrote:
Postby MichaelB » Mon Sep 09, 2019 9:22 am
I did have a quiet chuckle at that.Duck! wrote:Don't think that's quite the proof of concept they intended!MichaelB wrote:
Postby MichaelB » Mon Sep 09, 2019 11:18 am
Postby biker jk » Mon Sep 09, 2019 11:44 am
Here's Hambini confirming that seal drag is a significant multiple of the rolling friction of the balls.Duck! wrote:Most of the drag in a regular bottom bracket is the seals rather than the bearings. Shimano models in particular have a dirt seal under the outer cover that does drag a fair bit, but it's very effective at keeping crud out of the bearings. Gently lifting off the outer covers & applying a bit of Slick Honey grease or silicon lube to the lip of the inner seal cuts drag enormously.g-boaf wrote:
Postby P!N20 » Mon Sep 09, 2019 2:07 pm
2 watts?MichaelB wrote:Good explanation of how little the theoretical gains are in reality, even IF they did work …
Postby MichaelB » Mon Sep 09, 2019 8:21 pm
Postby Trevtassie » Mon Sep 09, 2019 9:59 pm
Postby AUbicycles » Wed Sep 11, 2019 6:50 am
Postby Alex Simmons/RST » Wed Sep 11, 2019 6:59 am
Postby MattyK » Wed Sep 11, 2019 9:10 am
It's not, this has been proven over a century and a half, and someone as competent as Jason Smith should be embarrassed to have his name near this.AUbicycles wrote:... I think the positive is that a brand working and trying it out to see if it is viable...
Postby RobertL » Wed Sep 11, 2019 9:23 am
The best thing I saw in that article was the curvy tube nozzle thingy for the WD-40. That's groundbreaking!AUbicycles wrote:I publish a writeup of it which put it all in perspective. I went back to the stand a few times but never got to see it in action. Apparently it was working again... but was having issues - very much a prototype.
Eurobike Highlights and the Truth behind the Ceramic Speed bicycle drivetrain
In summary, the marketing is over the top... but it drives attention and business to their coated chains and jockey wheels.
But, they are genuinely working on it and trying to get the shifting to work and their suggestion is that in 6 months they will have solved it... but I still don't believe it will be market ready then. In fact, they will be looking for a partner when they are ready.
The aero was not convincing... it is just a cover and as there is no derailleur, of course there is less bits to distract airflow.
The rideable model (up to 45kmh) was unfortunately a single-speed and not shiftable and was not available to test.
And then there is the question of torque... this still needs to be addressed and the idea is that we see a completely new wheel design where the cassette is attached to the hub and wheel - perhaps a one piece wheel.
But there is also an issue that when the chain is engaged, instead of have of the teeth of a chain ring or jockey wheel or cassette being connected to the chain - the ceramic speed has 1 - 2 teeth in total connected to the cassette at any one time. If the drive is also pressed too tightly against the cassette to help power transfer then this also increases friction. Previous generation drive-shafts have teeth rather than bearings and they can transfer torque but at the cost of power efficiency (compared to a classic chain).
To put the ensure drivetrain in perspective... we have to remove the marketing a bit and we have to remove the expectation that it will be market ready in the near future.
But I think the positive is that a brand working and trying it out to see if it is viable. If the marketing could tone it down... it would be far more interesting to track this project and check in to see progress and they continue the development.
Postby AUbicycles » Wed Sep 11, 2019 4:00 pm
Then sit back and enjoy the ride. If they then put it on some high-end $20,000 bikes with the disclaimer "don't pedal too hard" then you can smile knowing it is not your money.MattyK wrote:Damn it makes my head hurt to think that people think this is realistic.
Postby 10speedsemiracer » Wed Sep 11, 2019 4:38 pm
sums up the entire project.Until then, the marketing has been great, media and consumer interest in the regular Ceramic Speed bearings and coated chains is booming.
Postby Alex Simmons/RST » Wed Sep 11, 2019 6:41 pm
Postby MichaelB » Thu Sep 12, 2019 9:57 am
Fixed it for you !Alex Simmons/RST wrote:Kind of likean April fool's joke that's overextended its welcome.
Postby AUbicycles » Fri Sep 13, 2019 6:41 pm
Postby MichaelB » Fri Sep 13, 2019 6:58 pm
Postby 10speedsemiracer » Fri Sep 13, 2019 8:51 pm
This makes me so happy. The fact that this Portuguese business is conducting stress-testing utilizing real-world modelling based on Melbourne suburban roads is wonderful...AUbicycles wrote:I will ask them if it can do this...
https://www.instagram.com/p/B2CH5j3Ihzw ... yclesnetau
The instagram video (in the link above) shows a test rig from a Portuguese brand call Miranda who have a chainring design that helps prevent chaindrop.
Postby AUbicycles » Fri Sep 13, 2019 11:07 pm
Postby AUbicycles » Wed Sep 25, 2019 8:38 pm
Postby MichaelB » Thu Sep 26, 2019 7:36 am
Postby AUbicycles » Thu Sep 26, 2019 5:25 pm
Let me ensure that I have this covered...Christopher Jones wrote:One of the most interesting suggestions from Jason Smith is that the concept of the cassete, hub, spokes and wheel can be reimagined.
