I’ve had no sealant leak out. They are hooked rims with sealed rim beds so I put it down to them not being seated properly. I gave them another bit of air today and they both seem to be holding 70+ psi. I was going to change the valve cores, but probably no need. Will wait and see what happens with them. I’m off the bike for the next week (Doc’s orders). Ideally, I’d like to take another spin to see how they hold up.Mr Purple wrote: ↑Wed Jan 03, 2024 12:46 pmIs it leaking from the bead or from the actual sidewall of the tyre? If it's the first it's just probably not seated on the bead properly, so I'd fix that.kilroy wrote: ↑Wed Jan 03, 2024 9:33 amI've just had an issue with 32mm Gravel Kings on a Bontrager Aeolus 37 Pro rim. 60ml of Orange sealant in each one. Tyres both seemed to seat using a Lezyne Pressure Over Drive pump. Both held air to about 60 psi, but any more and air seemed to escape from the tyre wall. I went for a ride to try to work the sealant around but no change. Both still holding air but cannot go above about 60psi. Any pointers?
If it's from the sidewall it's just some air leaks from the tyre itself and the sealant will fix it. I'd ride them at 60PSI for a week or so and see how they go (60 PSI on a 32mm tyre is a pretty reasonable pressure unless you're super heavy).
Also is it just air or actual sealant coming out?
Tubeless roadbike tyres
Re: Tubeless roadbike tyres
Postby kilroy » Wed Jan 03, 2024 2:38 pm
Postby Mr Purple » Wed Jan 03, 2024 2:53 pm
I often lose 10-20PSI overnight for the first week, and then they settle.
I assume it's just little gaps that need to be filled with sealant.
Postby warthog1 » Wed Jan 03, 2024 3:58 pm
Have used gravel king slick, ss and sk. Have not had the pressure drop. Have just needed a high flow compressor to seat them.
60 psi is quite a bit of pressure in such a large tyre too.
I have a 28f and 32r on my admittedly wide WR50s (25mm int).
55 psi at each end is very firm, almost too much at my weight 76-78kg
![Wink :wink:](./images/smilies/icon_wink.gif)
- twizzle
Postby twizzle » Fri Jan 05, 2024 3:57 pm
The leak was from a cut that will need to be patched. The whole inside of the tyre is like a latex balloon which didn't stick to the rim tape! No sealant left, it's all in a puddle just down the road from my house.
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Postby Mr Purple » Fri Jan 05, 2024 6:39 pm
These things happen, which is why you need to carry a tube and the usual puncture repair stuff and jus thope you never need it.
Postby warthog1 » Fri Jan 05, 2024 6:57 pm
I have found my puncture rate on road vastly reduced though.
Postby caneye » Mon Jan 08, 2024 10:29 am
but if it is wide or long enough, and requires an internal patch/boot, then that will be impossible to do mid-ride?
once you break the tubeless tyre-wheel seal, it's impossible to re-seat and recreate a tubeless seal when outside.
the only emergency option is a tube?
just thinking out loud.
Postby Mr Purple » Mon Jan 08, 2024 10:56 am
Yes, essentially.caneye wrote: ↑Mon Jan 08, 2024 10:29 amam i right to think that - I can fix a small puncture via plugs or darts or bacon strips, without removing the tyre from the wheel.
There is a small enough hole that you can plug without removing the tyre. If you remove the tyre you will need to reseat the tyre, and although not impossible it is very difficult on the road (you may be able to use a CO2 cannister but will need to replace the sealant afterwards).
With that in mind the thought process that comes with a tubeless puncture on the road should be:
1. Will the sealant fix it? Turn it puncture down, hold some pressure on the outside of it and hope.
2. Will a plug fix it?
3. Will I need to remove the tyre to fix it? In which case you're better off sticking a tube in. Pretty hard to adequately patch something from the inside by the side of the road when it's covered in sealant, and at this stage you're just trying to get home, really.
There are occasions where none of these things will work and I've had it happen to me twice. To be honest it's first because I had terrible plugs, and a terrible pump. On the one occasion I had everything to fix it and still couldn't do it, it was a puncture that also would have needed a ride home if I was running tubes. It was just massive.
- MichaelB
Postby MichaelB » Mon Jan 08, 2024 12:20 pm
Now that I have the ICAN Groadie, the commuter tyres are now different. Hit me up for a bargain, have 4 off BNIB
Postby warthog1 » Mon Jan 08, 2024 12:21 pm
A CO2 cartridge may reseat but I wouldn't be relying on it.
I carry bacon strips on the gravelbike with lower pressures also a tube. On the roadie just a tube. Had to use a tube on the road once in >20k km. That was a clogged valve as the cause
Postby ningnangnong » Thu Jan 11, 2024 2:47 pm
As someone with almost zero 'handyman' ability or knowledge, what specs will be sufficient purely to seat tyres? I can't imagine any other uses at this stage haha.
Would this do - https://www.bunnings.com.au/ozito-6l-1- ... t_p0048827 - or do I need something with a higher flow rate?
Edit: Just noticed one reviewer said they bought that model to seat tubeless tyres and it works fantastically!
Postby BoNeZ » Thu Jan 11, 2024 3:52 pm
Bunnings will probably return is if it doesn't work for you.ningnangnong wrote: ↑Thu Jan 11, 2024 2:47 pmI'm looking at buying an air compressor to use for seating particularly stubborn tyres - mainly because I'm sick of furiously pumping like a maniac!
I brought one of these then returned it for something bigger. It wouldn't inflate the stock Giant Gavia 700x32's that came standard on my Contend AR. My new bigger 40L compressor sits almost unused in the garage but it works well.
Postby vosadrian » Thu Jan 11, 2024 6:10 pm
Cheers!
Postby blizzard » Thu Jan 11, 2024 6:31 pm
Postby vosadrian » Fri Jan 12, 2024 9:35 am
- twizzle
Postby twizzle » Fri Jan 12, 2024 5:39 pm
You're talking to the guy who used to carry a spare tyre in the backpack and once went through five tubes in one wet ride.Mr Purple wrote: ↑Fri Jan 05, 2024 6:39 pmI think regardless of how expensive and fancy a sealant you use (Silca I suspect given the carbon!) I doubt it's going to ever seal a decent sized cut.
![Laughing :lol:](./images/smilies/icon_lol.gif)
Anyway - I tried to setup the original Giant Gavia tubeless on a Velocity A23 last weekend. Didn't work - I set it up years ago with two layers of generic yellow tape and tubeless wouldn't bead up, even at 100psi on the belt-drive compressor. Velocity warns that you need thin tape, but I'd say the clearances are too tight. I'd had issues in the past where I couldn't get the tyre back on the bead after a roadside repair.. I might just stick with latex tubes for other bikes.
- grt046
Postby grt046 » Sun Jan 14, 2024 10:00 pm
They still have stock .... I wonder why
- foo on patrol
Postby foo on patrol » Mon Jan 15, 2024 6:44 am
![Shocked :shock:](./images/smilies/icon_eek.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Foo
Goal 6000km
Postby am50em » Mon Jan 15, 2024 7:08 am
Vittoria introduces the limited-edition Corsa PRO Gold adorned with golden sidewalls. It comes in numbered double-packs, featuring two Corsa PRO tubeless-ready tyres with gold sidewalls and with a serial number written by hand on the inner side of the tyres. Only 2,023 packs are available globally: a true collector’s item for any road cycling lover.
- MichaelB
Postby MichaelB » Mon Jan 15, 2024 8:28 am
am50em wrote: ↑Mon Jan 15, 2024 7:08 amVittoria introduces the limited-edition Corsa PRO Gold adorned with golden sidewalls. It comes in numbered double-packs, featuring two Corsa PRO tubeless-ready tyres with gold sidewalls and with a serial number written by hand on the inner side of the tyres. Only 2,023 packs are available globally: a true collector’s item for any road cycling lover.
![Image](https://i.imgflip.com/1nmzfd.jpg)
Postby Mr Purple » Mon Jan 15, 2024 1:00 pm
I reckon with the mileage I'm likely to get out of the 'pro' versions that'd cost me 30c per kilometre.
Postby warthog1 » Mon Jan 15, 2024 2:30 pm
Seems to be largely advocated by "tobinhatesyou".
Pretty thin and not as stiff as tape that is designed for the purpose it seemed to me.
Not impressed on my wheels and ordered some from the wheel manufacturer.
Possibly my fumble fingered application had something to do with it, but the purpose designed stuff went on ok.
These are handy for tubeless tyre use. Inevitably the valve core seems to clog over time.
Whip it out and replace it solves that.
https://www.ebay.com.au/itm/12625576976 ... media=COPY
- grt046
Postby grt046 » Mon Jan 15, 2024 5:15 pm
Thanks .... I have ordered somewarthog1 wrote: ↑Mon Jan 15, 2024 2:30 pm
Postby warthog1 » Mon Jan 15, 2024 9:45 pm
grt046 wrote: ↑Mon Jan 15, 2024 5:15 pmThanks .... I have ordered somewarthog1 wrote: ↑Mon Jan 15, 2024 2:30 pm
I got some reserve fillmore valves on another set of wheels.
https://www.bikeperfect.com/features/be ... ves-around
Not cheap.
Wont bother again. The replacement valves on ordinary goers seems a better idea.
- All times are UTC+11:00
