Gravel lube.
Gravel lube.
Postby warthog1 » Sun Oct 17, 2021 9:58 am
What sort?
How do you clean the driveline?
How many ks from a chain?
I am expecting chains and cassettes to wear more quickly than on the road due to sand and grit making a grinding paste.
A wax lube would seem to be less likely to hang onto sand and dust than a wet lube.
I am hoping there is a drip on product that works well.
Currently using smoove on the roadies, but it stays a bit moist/tacky, so I expect it to hold onto too much crap.
I have to admit I am not really interested in setting up a slow cooker and going wax bath.
I suspect that may be the advice though. If so fair enough.
- RonK
Re: Gravel lube.
Postby RonK » Sun Oct 17, 2021 10:07 am
Squirt on, wipe off, ride.
Use a chain cleaner once a year.
Re: Gravel lube.
Postby warthog1 » Sun Oct 17, 2021 10:19 am
I am liking that.
No faffing around heating wax removing chains etc.
Still, I will be doing a few ks and you can apparently do a few chains in the wax concoction at the same time to make it less annoying.
Re: Gravel lube.
Postby Propagate » Mon Oct 18, 2021 6:38 am
I tried waxing for a year or so on the gravel bike and MTB. Chain off, thoroughly cleaned in de-greaser in an ultrasonic cleaner then dropped into hot chain wax in a slow cooker.
Sublime when first done and would last roughly 300k between waxings, BUT, when it goes it goes. Like mid way through a ride going from smooth and quiet to rough as a bag of hammers.
The worst bit though, I got less than 1,000 out of a brand new chain on the gravel bike before the chain tool showered over 75% wear and less than 500k on the MTB!!!
Back to the Rock N Roll lube and current gravel chain is approaching 3,000k and not even at 50% wear yet (same model chain).
Re: Gravel lube.
Postby warthog1 » Mon Oct 18, 2021 8:13 am
With the RnR do you clean the chain between rides, or just keep dripping the lube on?
Re: Gravel lube.
Postby Propagate » Mon Oct 18, 2021 10:36 am
- trailgumby
Re: Gravel lube.
Postby trailgumby » Mon Oct 18, 2021 1:01 pm
- cancan64
Re: Gravel lube.
Postby cancan64 » Mon Oct 18, 2021 1:19 pm
Re: Gravel lube.
Postby Nobody » Mon Oct 18, 2021 1:55 pm
Re: Gravel lube.
Postby warthog1 » Mon Oct 18, 2021 1:57 pm
I dont find chain maintenance and lubing very inspiring either
That sounds like a workable management plan for me too
Thanks.
Re: Gravel lube.
Postby warthog1 » Mon Oct 18, 2021 2:30 pm
I am unsure what you mean by 800km?
800k per lube sounds too far and 800k per chain is too short.
Re: Gravel lube.
Postby warthog1 » Mon Oct 18, 2021 2:34 pm
My experience with wet lube on the roadie is it hangs onto dirt and makes a grinding paste.Nobody wrote: ↑Mon Oct 18, 2021 1:55 pmI just use whatever wet lube. Wipe, lube, wipe and I never clean my chains. I take a rag out on my first ride and once the crud has attached to the small amount of remaining lube on the outside, I wipe it off. Then it's just a matter of keep wiping the chain as necessary. That is until such time as the chain doesn't run well anymore, then I start again. I keep the chain as dry as possible on the outside as we only need lube on the inside of the chain. I don't monitor how far I ride since I don't have anything extra on the bike that can also get broken in the next crash.
I have switched to smoove and chains are lasting far longer.
I want something that ends up dry to form less of a grinding paste.
Smoove ups up a bit tacky, I want a drier lube for the dirt.
- cancan64
Re: Gravel lube.
Postby cancan64 » Mon Oct 18, 2021 3:54 pm
800km per chain... In the habit now of lubing each ride since its wet lately... and tell a lie, my excel formula was wrong, 1436km for a Sram 1170 chain which I will be changed this weekend and admittedly, there is a lot of water around (mud) and lockdown rides consist of climbing and more climbing
Re: Gravel lube.
Postby warthog1 » Mon Oct 18, 2021 6:40 pm
Yeah mud and water has got to hammer it.cancan64 wrote: ↑Mon Oct 18, 2021 3:54 pm800km per chain... In the habit now of lubing each ride since its wet lately... and tell a lie, my excel formula was wrong, 1436km for a Sram 1170 chain which I will be changed this weekend and admittedly, there is a lot of water around (mud) and lockdown rides consist of climbing and more climbing
Hoping for longer than that, we'll see.
Pick the bike up tomorrow
Re: Gravel lube.
Postby Propagate » Tue Oct 19, 2021 6:13 am
The RNR is "wet" as it it's like a wax suspended in a paraffin type solution, you literally squirt as much on as you're wallet allows then try and wipe all of it back of with a rag. What's left evaporates and leaves the little waxy particles behind.warthog1 wrote: ↑Mon Oct 18, 2021 2:34 pmMy experience with wet lube on the roadie is it hangs onto dirt and makes a grinding paste.Nobody wrote: ↑Mon Oct 18, 2021 1:55 pmI just use whatever wet lube. Wipe, lube, wipe and I never clean my chains. I take a rag out on my first ride and once the crud has attached to the small amount of remaining lube on the outside, I wipe it off. Then it's just a matter of keep wiping the chain as necessary. That is until such time as the chain doesn't run well anymore, then I start again. I keep the chain as dry as possible on the outside as we only need lube on the inside of the chain. I don't monitor how far I ride since I don't have anything extra on the bike that can also get broken in the next crash.
It sort of squeezes out the crap too, so once you're done squirting you'll find a ton of black dirt on your wipe rag (even if you've half assed cleaned the chain first).
You'll still get a chain tattoo on your calf at times, but it's nothing like a chain oil as such.
Re: Gravel lube.
Postby Propagate » Tue Oct 19, 2021 6:16 am
As said earlier, I got less than 1,000 from a new chain when using a hot wax method and was mortified.
Currently on 3,000+ k on the gravel chain after ditching wax and going back to blue RNR, through winter riding and lots and lots of sandy gritty gravel (and barely a squirt with a hose between rides) and I've not even hit 50% on the chain wear tool guide yet, which is much more like what I'd expect to see.
Re: Gravel lube.
Postby warthog1 » Tue Oct 19, 2021 7:59 am
Yeah I've used RnR gold before.Propagate wrote: ↑Tue Oct 19, 2021 6:13 am
My understanding is a wet lube stays wet. I understand the wax lubes in a bottle go on wet. They dry out though, once the carrier fluid has evaporated.
True wet lubes don't dry out and dirt sticks to them ime.
Re: Gravel lube.
Postby warthog1 » Tue Jul 05, 2022 5:20 pm
It is almost out though.
I have some finish line ceramic wax and some squirt.
Neither are as thin as the white lightning.
I printed off the zero friction cycling report on Squirt.
Have had a brief squiz.
It is fairly thick and apparently has trouble getting inside the rollers on an 11 speed chain.
Particularly in winter I am guessing, when it just goes thick on contact with the cold chain.
Probably an argument for hot wax bath immersion. Cbfed though tbh.
Think I'll try to source some more white lightning clean ride at least for winter.
It works ok.
Re: Gravel lube.
Postby lone rider » Sat Mar 16, 2024 11:27 pm
Re: Gravel lube.
Postby warthog1 » Sun Mar 17, 2024 11:23 am
Re: Gravel lube.
Postby Nobody » Sun Mar 17, 2024 3:03 pm
https://zerofrictioncycling.com.au/lubetesting/
Subjectively speaking, I tried a drip type wax lubricant about 30 years ago and in the wet it was poor performing to the point where the drive train stopped working properly. I was advised by a bike shop to use something else so I ended up with - the now known to be poor performing - drip wet lubricants. Once again subjective, but I find the environmental footprint of my use in regard to chemical use is quite low for these. I keep the original grease on, but coat it in wet lube as this attracts less dirt. As said previously I also try to keep the outside of the chain dry by repeated wiping. Sometimes wiping more than once per ride. Good enough for me, but I may try one of the better drip waxes in the future if I want to be more of an enviro-vandal in degreasing a chain.
As for hot dip waxes, I'm just not in love with cycling or my equipment enough to do this. My off road equipment is usually cheap because it's only going to get trashed anyway. I don't track the distance because I don't care enough.
Re: Gravel lube.
Postby warthog1 » Sun Mar 17, 2024 3:38 pm
I drop the chain in a staminade container with about 25mm deep bath of mineral turps. Let it soak and swish it around. Then do the same with methylated spirits twice. I tip the fluids on my firewood stack.Nobody wrote: ↑Sun Mar 17, 2024 3:03 pmThanks WH1 for mentioning Zero Friction Cycling. Link below for others to find.
Using flower power wax at the moment but have used a few others.
Doing the same for road and gravel. Oil based lubes are pretty soon grinding paste on the gravel and much harder to clean.
That'll do me. I am sure a wax bath is better but I simply cant be bothered.
Re: Gravel lube.
Postby blizzard » Sun Mar 17, 2024 6:29 pm
Road bike I have 2 chains on rotation using a homemade immersive wax but next waxing they will be used with Silca Hot Melt + top up with the drip wax (same as the cargo bike).
Re: Gravel lube.
Postby Nobody » Sun Mar 17, 2024 8:04 pm
warthog1 wrote: ↑Sun Mar 17, 2024 3:38 pmI drop the chain in a staminade container with about 25mm deep bath of mineral turps. Let it soak and swish it around. Then do the same with methylated spirits twice. I tip the fluids on my firewood stack.
Thanks for posting. The video was more interesting than I thought it was going to be.
I'm just reading ZFC's "Key Learnings From Lubricant Testing"
https://zerofrictioncycling.com.au/wp-c ... g-2.3a.pdf
He makes a good case for top performance immersive waxing products. If I had something better than an old 26" rigid MTB with a cheap drive train I might consider it.
Re: Gravel lube.
Postby Nobody » Tue Mar 19, 2024 9:17 am
Return to “Cyclocross and Gravel Grinding”
- All times are UTC+11:00
