SO... Cannondale Topstone Neo Lefty 3 e-Gravel (what a mouthful!) has made it to my garage eventually!
![Image](https://live.staticflickr.com/65535/52131231660_2e3464c08c_c.jpg)
First test ride around the crappy local Williams valley roads and a few dirt roads were, to be quite truthful, a bit of an eye-opener.
I can see why people get hooked on e-bikes - I didn't use anything but ECO mode and the hills seemed to melt away! The Bosch system is a bit 'Aggressive' in the way it assists you at times but you soon get used to it. Could be interesting on steep gravel roads maybe....
The bike itself, as a bicycle, is a delight to ride. Very sharp handling, the disc brakes work as advertised and the ride was very comfortable once set up to my requirements. The gravel front and rear suspension did a good job of softening the impact of the linked potholes that comprise the road system around here at the moment and the tyres (somewhat to my surprise) handled the loose surface of the gravel roads very well.
This will be used for light touring, so fitting luggage looks like it might be a challenge. Current thinking is an Ortlieb handlebar bag and my Carradice touring saddlebag for pub based touring. Where I'm going to put a front light once the handlebar bag is fitted is going to be a problem.
Any suggestions on either of the above points appreciated!
