Hi all, currently running compact road 50/34 into a Sram 11-36 cassette on my ScottAddict but would really like a lower bottom gear.
Could I just bung a GRX FD and 46/30 crankset on there ?
Mike
GRX 46/30 Cranks on 2019 ScottAddict 20 ?
- cyclotaur
Postby cyclotaur » Sun Dec 11, 2022 8:41 pm
2023 Target: 9.500kms/100,000m
My old blog - A bit of fun
Re: GRX 46/30 Cranks on 2019 ScottAddict 20 ?
Postby warthog1 » Sun Dec 11, 2022 9:04 pm
Or a 48/31 grx chainset so you lose less top end.
I assume it will work but don't know for sure sorry.
Dogs are the best people
- cyclotaur
Postby cyclotaur » Sun Dec 11, 2022 10:44 pm
Top end not a problem, trust me !
Postby caneye » Mon Dec 12, 2022 12:09 pm
Check the width of the GRX crankset to make sure it doesn't mess around with your current front derailleur.
https://www.ridecx.com/blogs/learn/unde ... -cranksets
- cyclotaur
Postby cyclotaur » Mon Dec 12, 2022 2:03 pm
Good article. This is why I mentioned GRX cranks AND front derailleur.caneye wrote: ↑Mon Dec 12, 2022 12:09 pmCheck the width of the GRX crankset to make sure it doesn't mess around with your current front derailleur.
- Duck!
Postby Duck! » Sun Dec 25, 2022 3:58 pm
GRX is just slightly modified road gear, and mostly interchangeable. Biggest difference is in the front chainline; GRX places the chainrings a bit further outboard to accommodate wider chainstays dictated by wider tyres, therefore has a wider-stanced FD to match. You could possibly tweak the road FD's limits to swing it out that bit further, but it's safer to get crank & FD as a pair. They will play fine with the rest of the system.
Postby LateStarter » Mon Dec 26, 2022 12:28 pm
Is this currently 10 or 11sp? currently have triple cranks (24-36-48) &12-36 rear, currently 9sp but has been 10 changing only the right level (Sora for 9, ultegra for 10). It also used to be 2x10 (46-30, both levers ultegra & FD). I might go back to a 46-30 with a GRX (10sp) but really then want a bigger cassette, 11-42 would be really nice but don't know if the ultegra levers would still do the job? Want to change as little as possible.
Bill (Long Distance Dreamer)
2008 Cannondale Touring, 2013 Vivente World Randonneur, 2015 Lynskey Sportive (Audax)
- cyclotaur
Postby cyclotaur » Mon Dec 26, 2022 2:00 pm
Thanks Duck that's the answer I was looking for.Duck! wrote: ↑Sun Dec 25, 2022 3:58 pmGRX is just slightly modified road gear, and mostly interchangeable. Biggest difference is in the front chainline; GRX places the chainrings a bit further outboard to accommodate wider chainstays dictated by wider tyres, therefore has a wider-stanced FD to match. You could possibly tweak the road FD's limits to swing it out that bit further, but it's safer to get crank & FD as a pair. They will play fine with the rest of the system.
- Duck!
Postby Duck! » Sat Jan 14, 2023 7:34 pm
GRX, even in 10-sp. form is based on 11-sp. architecture which has a different cable stroke which is incompatible with most other 10-sp. shifters. You'll need a GRX400 or 4700 Tiagra shifter to work. Although the derailleur can fit a 11-42 cassette, it won't do it paired to a 16T chainring difference, it doesn't have the length to take up the chain slack. Maximum possible chainring difference is 14T. Or if you really wanted tthe 46-30, your maximum cassette is 11-40.LateStarter wrote: ↑Mon Dec 26, 2022 12:28 pm......currently have triple cranks (24-36-48) &12-36 rear, currently 9sp but has been 10 changing only the right level (Sora for 9, ultegra for 10). It also used to be 2x10 (46-30, both levers ultegra & FD). I might go back to a 46-30 with a GRX (10sp) but really then want a bigger cassette, 11-42 would be really nice but don't know if the ultegra levers would still do the job? Want to change as little as possible.
- All times are UTC+11:00
