The spokes had broken mid body with the trike just stationary in the house, unused for months. They did have some corrosion from a coastal environment, but spontaneous fracture?
![Confused :?](./images/smilies/icon_confused.gif)
I ordered replacements from Custom Cut Spokes (thanks for the recommendation, Duck), but they were too short. A combination of me measuring a slightly bent original spoke, plus the originals being shorter than ideal to start with.
Another batch of spokes arrived from overseas, and on to building the wheel.
Hmm. How to use a truing stand with a wheel with only 1 axle (spindle)? I made a second axle anchored into the hex hole on the outside of the hub. The new axle had a very slightly smaller (0.6mm) diameter than the real one, so I placed a shim in the truing stand "V" that holds the axle.
Hmm. Small wheel, high spoke count; my favourite spoke key only just turns between the adjacent spokes.
Hmm. Small wheel, 2X pattern; my tensiometer has no chance of taking measurements. Being tone deaf, I relied instead on the feedback from turning the nipples to even out the tension.
Hmm. Disc brake, only 1 axle. How do I determine the dish? Decided to centre the rim between the hub flanges & ignore the brake disc (irrelevant with just one axle), but unable to use my dishing tool properly because the wheel was so small, and there was a long blimmin' axle sticking out from only one side.
There was further sweating and cursing adjusting the cable disc pads to avoid any rub (nothing is easy working on a large recumbent trike without a stand), then pumped up the tires, lubed the chain, and took Mum for her first ride since a serious health scare 12 months ago.
The smile on her face as she slowly pedaled along the waterfront made it all well worth while.
