Hello everyone!
I am planning to put MAFAC RACER centerpull brakes on a project bike. I am 90% there, just got a bit stuck with the brake cable ferrules. They appear to be stepped, and I don't have any.
I can see some stepped ferrules on Velo Orange website 5mm to 4 mm. However I am not sure if MAFAC were of the same dimensions. Anyone has any experience with them?
Thanks!
Mik.
Mafac brake cable ferrules
Re: Mafac brake cable ferrules
Postby LG » Sun Aug 25, 2024 8:22 pm
Which part of the brakes are you referring to, where the cable exits the brake lever? Or one of the cable hangers (headset or seatpost?
LG = Low Gear
Postby Mickey1980 » Mon Aug 26, 2024 12:45 am
Hi!
I am talking about the part of the cable that is going into cable hangers. Those seem to require stepped ferrules to stay in place.
- Clydesdale Scot
Postby Clydesdale Scot » Mon Aug 26, 2024 7:36 am
the dimensions are here
https://www.ebay.co.uk/itm/256119541694
- WyvernRH
Postby WyvernRH » Mon Aug 26, 2024 9:04 am
IIRC you don't actually need the stepped ferrule for the rear hanger? Later (70's?) models of the front Mafac hanger have a little 'kick-up' at the front of the lip which helps retain a non-stepped ferrule, maybe look for one of those?Mickey1980 wrote: ↑Mon Aug 26, 2024 12:45 amHi!
IMHO the front hanger is a bit of a liability anyway as it flexes badly which reduces brake effectiveness considerably. If you are not too worried about detailed originality replace it with a Weinmann or Dia-Compe front hanger. This was a standard fix back in the day to improve the braking when touring. That or drilling the stem - possibly not recommended
Postby Mickey1980 » Mon Aug 26, 2024 1:58 pm
I have seen these. The price is pretty steep - over $10 per ferrule plus shipping from the UK. I was wondering if this was a proprietary size, or any 5 to 4 ferrule would work?Clydesdale Scot wrote: ↑Mon Aug 26, 2024 7:36 amthe dimensions are here
E.g. this
https://velo-orange.com/products/tapere ... 5mm-to-4mm
Postby Mickey1980 » Mon Aug 26, 2024 2:26 pm
Thanks for the hint. I will check my front cable hanger - it looked sturdy with some shape added for rigidity. The problem is that I also have the rear to worry about - I need one for the pulley (mixte style)WyvernRH wrote: ↑Mon Aug 26, 2024 9:04 amIIRC you don't actually need the stepped ferrule for the rear hanger? Later (70's?) models of the front Mafac hanger have a little 'kick-up' at the front of the lip which helps retain a non-stepped ferrule, maybe look for one of those?
- Clydesdale Scot
Postby Clydesdale Scot » Mon Aug 26, 2024 5:04 pm
Postby Mickey1980 » Mon Aug 26, 2024 8:41 pm
I guess my question is whether these dimensions are proprietary MAFAC standards or more generic that can be found across the industry and whether practically anyone tried to interchange.Clydesdale Scot wrote: ↑Mon Aug 26, 2024 5:04 pmI wrote that the measurements are found in that listing.
Comparing the dimensions of MAFAC to VO ferrules:
Large end: External diameter MAFAC 6.0 vs VO 5.75mm; internal diameter MAFAC 5.2 vs VO 5mm
Small end: external diameter MAFAC 3.98 vs VO 4mm; internal diameter MAFAC 2.3 vs VO 2mm.
The ferrule length I guess will be less important.
So the answer is: MAFAC appears to have a proprietary standard, unless the eBay ad had issues with measurements/ or there were vast tolerances in production process
Anyone has a hands on experience on interchangeability? The dimensions look close, but the external diameter of the smaller end may not fit in and may require some drilling...
Postby Mickey1980 » Wed Aug 28, 2024 11:52 am
Ok, a cheep and cheerful way to find the replacement ferrules for those who are on the budget and is not worried about participating in concours d:elegance
E6012 10AWG 6mm² Insulated Ferrule Bootlace Terminals Crimps.
They appear to be sturdy enough to keep the brake cable in place. I would still have a standard 5mm ferrule on the cable end just in case.
Postby hunch » Fri Aug 30, 2024 6:47 pm
Wouldn't think those ^^^ would be all that great in compression.
If you could find someone with a swiss lathe, you could turn out several thousand in a few hours and corner the market!
- All times are UTC+11:00
