srl wrote:Hey rdp, which way do you go to get home? I'm interested in various routes, as I live at Thornleigh and commute to Macquarie Park, but doing best to avoid main streets. After KPR, I zip down Rohini past Turramurra Stn, then through a path next to rail line to Cherry St. Take that to Bangalla, turn l, r onto Young, then l to Billyard. Follow that to Wahroongha, on to Alexander and up to Waitara before wending home on back streets.
SRL,
I'm Macquarie Park to Westleigh.. so very similar route choices.
This sounds like your KPR / Waitara option.. the hop onto Pennant Hills Rd footpath for a hundred meters or so to meet up with the brickpit cycleway is a good way to get through that last bit :
http://www.strava.com/activities/67217000" onclick="window.open(this.href);return false;
For the western option, I use Beecroft Rd or Sutherland depending on how I feel at the time, and traffic. I find Yarrara ok getting out of Thornleigh/Pennant Hills, then onto to footpath at Trebor Rd (or earlier) to avoid trying to match the traffic up PH Rd to Beecroft.
Once at the top of Observatory Hill, wait for the lights, then its fast down Beecroft Rd, maybe with a duck at the first or second left to get onto Sutherland. I rarely bother with the back streets and steps these days. here's a fast one from the other day where I got to draft a concrete truck down
http://www.strava.com/activities/75005814" onclick="window.open(this.href);return false;
Coming home, its M2 underpass (if not flooded) then Sutherland and a bit of naughty footpath work again up Beecroft Rd from Albert Rd all the way around to Trebor on PH Rd to avoid the steps.
http://www.strava.com/activities/73073015" onclick="window.open(this.href);return false;
If you like quiet streets, and depending on where in Thornleigh you are, you can duck parallel to Yarrara through Trebor/Rosemount/Tillock/Morgan/Dale, through past the sewer pumphouse onto Edmunson Cl - but beware, its hilly!
Surprised you found a nutter down the East Side of PH Rd.. its very sleepy down there!
